Charger power steering pump refit problem
I've removed the pump, replaced all of the seals and o-rings etc to solve the leaking problem.
Refitted the unit today and fired it up, filled it with fluid yet my steering is not powered.
Any issues spring to mind? It has sat a while with no fluid in so the float adjustment thing will need tweaking but usually after a drain of fluid the wheels pull to the left by themselves due to that float having sunk to the bottom.
However, I have nothing, no power steering at all. The steering wheel is hard, manual. The wheels do turn but its a huge effort.
Have I missed a step? Something obvious? I followed the workshop manual and followed every step.
I'm confused. Apart from the leak it was working fine when I removed it.
:read2: :help: :scratch:
Power steering pump.jpg (156.46 KiB) Viewed 381 times
Rebel
Post by Rebel »
Hi Mate, how you doing ? not seen you for ages
Sorry, I aint well up on power steering pumps, all I can think of is maybe it could be an air lock, possibly.
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
Alright chief.
I've been working a lot recently which has been nice.
Two movies this year and another one starting in September (fingers crossed)
Hoping it's something simple in the steering, I'll give it another go tomorrow.
What is the best way to get rid of an air lock?
andyrob
Post by andyrob »
Dukerich wrote:What is the best way to get rid of an air lock?
just keep working the steering full lock to full lock with engine running & keep checking the fluid level
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
Ok. Will do. Cheers Andy.
The steering is really resistant. The wheels do turn but it's incredibly hard.
Is that still an air lock?
charger01
Post by charger01 »
Check that the pulley is actually spinning the shaft Rich.
It appeared to be. The bugger was tight enough to get back on(!)
System was working ok pre-removal apart from leaking.
Can an air lock be that resistant?
Rebel
Post by Rebel »
If the steering is that hard, try jacking the car up and put it on axle stands, then turning the wheel should be easier.This should at least let you know that the steering is o.k. I'm not sure if the wheels have to be on the ground to bleed the pump by turning lock to lock.
'68 Dodge Charger
‘75 Ford Ranchero
Makes sense.
That's tomorrows job then.
Cheers lads. :)
Been working lots recently.
Back in the garage now.
Power steering pump still not working.
Have cranked the wheel lock to lock a bunch of times with front wheels off the ground to reduce friction but after doing that for ages the fluid level is still not going down and I still have no power steering.
:help:
I want to make sure I've tried everything before I remove & check the pump in case I made a mistake during reassembly.
Any ideas?
ANTON
Post by ANTON »
Did you put the pressure relief spring and plunger back in correctly.
I thought I did.
Everything went back in the same way it came out as far as I'm aware.
The annoying thing is I went to a mate's place to use his pulley wheel puller.
So annoyed, it work (albeit with a leak) before I took it out.
:banghead: :dontknow: :-k :help:
Is there an online "how to" guide somewhere? I used my manual and followed the steps.
Just at a loss...
John
Post by John »
Maybe take the belt off and Undo the outlet hose, see if it pumps out when you spin it manually.
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Ok.
Will give that a go.
Wish I'd just decided to live with the leak now(!) ;)
