Knackered U/J
Rebel
Knackered U/J
Post by Rebel »
The U/J on the back of the prop (where it meets the diff) sounds and feels worn. Can anyone recommend the best place to get a replacement or are there any form of rebuild kits available?
TIA
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
andyrob
Post by andyrob »
well now youve joined all the race boys ,things like this are gunna happen
Try commerical propshaft @ team valley 0191 4821690, theve done a few yank props for me
when its in bits replace the saddles (u shaped bolts) that fasten the prop to the diff
& jack it up high on the axle to stop fluid running out g/box when you remove prop
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
Yes I have used them a couple of times.
If you need to supply them with new parts then try Hausers as Geof always has these sort of parts in stock.
Rebel
Post by Rebel »
Thanks both, thought I'd catch up on a few jobs that need doing while it's off the road waiting for the new ignition switch to arrive, :thumbright:
'68 Dodge Charger
‘75 Ford Ranchero
