Nickel Plating Kits
newport100
Nickel Plating Kits
Post by newport100 »
This kit contains everything required to plate items overnight with a high lustre finish and protection against corrosion.
Follow the comprehensive instructions for superb results every time.
Not to be confused with inferior products which use a poorly controlled power supply.
This kit has been specifically designed for the model engineer/restorer and has proven over the years to be the best available. All components of the kits are readily available if required. Fully guaranteed, with 24 hour back up, email service
£111.00
PRICE INCLUDES CARRIAGE- UK MAINLAND- ELSEWHERE PRICE ON APPLICATION
http://chronos.ltd.uk/acatalog/Nickel_P ... ml#aNCK100
