Posts: 8368 Joined: Sun Apr 18, 04 10:50 pm
Post
by db » Wed Feb 29, 12 11:38 am
Anyone know how this goes together?
I know it came out of there but it doesn't locate now, am i missing a guide or summat
Ashtray hole.jpg (88.87 KiB) Viewed 857 times
charger01
Posts: 3640 Joined: Thu May 26, 05 10:35 pm
Post
by charger01 » Wed Feb 29, 12 12:14 pm
Its upside down pal
Posts: 9563 Joined: Thu Feb 24, 05 10:31 am
Post
by Dave999 » Wed Feb 29, 12 1:28 pm
press fit?
but i'd expect there to be a rear tin so you can't flick lighted ciggys into the wireing
aussie charger one has the front door and bucket mount onto attachments that are integral to the rear tin which also includes the ciggy lighter
the rear tin is looped in from under the dash and is held by clips and screws to the back of the opneing
your is deffinitly different
you can see ball bearing rollers so i guess the front swivels up and down on them
does the outside of these fit into the taps either side of the opening?
if not you are missing the rear tin with the front door mounting on it
Post
by db » Wed Feb 29, 12 1:38 pm
The ashtray body slides forward in the bit with the balls, the whole assembly comes out for emptying if you press down on the sticky-up tag.
There must be a bit missing that fastens to the two lugs either side of the opening but i don't remember takin it off and gawd knows what i did with it
Post
by Dave999 » Wed Feb 29, 12 2:28 pm
yeah but even that set up still leaves the back of the hole open
i.e you could do a james herriot and pull out your bulkhead connetor wireing with the ash tray in situe
obvioulsy not implying that your car is a Friesian
i mean if you gave any 1930s yorkshire vets a lift the car could be damaged especillay if he stripped to his waist and you have a bucket of water and a big bar of soap to hand
he'd be in there saying i can feel the head followed by total loss of power to both ignition and lights
dave
Post
by db » Wed Feb 29, 12 7:51 pm
You paint a very colourful picture sir
Jules
Posts: 1850 Joined: Sun Sep 11, 05 2:28 pm
Post
by Jules » Thu Mar 15, 12 5:46 pm
You're missing this ............
Sorry it's a poor pic, it was in the background of 1 of my pics, and it's now installed in the car.
Hope it helps
ashtray housing.JPG (133.08 KiB) Viewed 756 times
MMA/750
Post
by db » Thu Mar 15, 12 11:18 pm
Brilliant cheers! Unfortunately i don't remember seeing one of those anywhere
Jules
Post
by Jules » Fri Mar 16, 12 12:34 am
MMA/750
Post
by db » Fri Mar 16, 12 7:36 pm
Nice one Jules, i've sent him a shipping enquiry
