They are here
Turnip
They are here
Post by Turnip »
I have just had the first batch of Quick Fuel carbs turn up
Q- Series Carburetors 650-1050 CFM DRAG - Built for the ultimate blend in performance and drive-ability. This carburetor features jet extensions and a notched float with all the tuning you features you would expect from a carburetor that's ready to race. Street duty is no sweat for the Q-Series with it's built in vacuum tubes and 4-corner idle.
Aluminum main body, and fuel bowl with QuickSet sight windows on both sides make for easy float adjustment
Billet metering blocks and throttle body ensure leak and porosity-free sealing between circuits
Each carburetor is hand-assembled and engine tested in the USA!
650 £630.00
750 £686.00
850 £738
Plus postage
Turnip
Post by Turnip »
Vacuum Secondary Street Carburetor - designed for street strip applications. Jet extensions and notched float make this carburetor strip ready while 4-corner idle, electric choke, adjustable secondary housing, and screw-in air bleeds help tune it for the street. All the features of our race carburetors merged into one street-friendly package.
780 £570.00
Turnip
Post by Turnip »
Drag Race Carburetors 750-850-950-1050
Dedicated and designed for the hardcore drag racer, this carburetor is easy to adjust and will provide unmatched performance. Made from premium aluminum throughout with billet metering blocks and throttle body it's lightweight and durable. Each carburetor is hand-assembled in the USA and individually engine tested - it's ready to race out of the box.
4-corner idle
Screw-In airbleeds that have been recessed and moved out of the air way for less restriction
Race style aluminum main body with upgraded downleg race boosters
5-Emulsion billet metering blocks with screw-in bleeds for every circuit fully adjustable
Lightweight aluminum fuel bowls with internal baffles, raised roof, re-designed fuel entry orifice and built-in sight windows
Quick-change jet plugs - allow for jet changes without removal of the fuel bowl (required screw driver is included)
Billet throttle body with Teflon® coated and sealed shafts that have been slabbed for added air flow, stainless steel throttle plates, and secondary adjustable cam bracket.
Each throttle body is machined for both 4150 or 4500 style manifolds.
750 £826.00
850 £870.00
Plus postage
All other styles and sizes available, just ask
I'd love one of those just to put it on the sideboard! :thumbright:
Turnip
Post by Turnip »
Ivor wrote:I'd love one of those just to put it on the sideboard! :thumbright:
What colour would you like :D
I'll ask the wife Jon! ;)
