Was just checking out the old post Baz started with wheel bearing part numbers and did a bit of a search to make sure they are the same used on the VG.
Came across this list that may be useful to others at some point.
http://www.alliedbearings.com.au/datasheets/chrysler
Link may die in time so a basic pic of the part numbers/specs below.
Aussie Val part numbers - seals
well handy
dba brakes cataloge has rotor sizes in it
http://www.dba.com.au/catalogue/online-catalogue/
kingrace bearings once you register allowes you to compare sizes
http://www.king-bearings.com/cat/
