EDELBROCK FUEL INJECTION
DaveBishop
Post by DaveBishop »
HI does anyone know what coil you use with the Edelbrock pro-flo fuel injection.
Cheers Dave
2 x 1969 Dodge Darts
DaveBishop
Someone must know I have seen a couple of cars using it on the board
Cheers Dave
I can't remember what fuel injection system Matt Snowball is using Dave, I was talking to him at Brooklands yesterday, either way, I bet he'd know...
DaveBishop
Thanks Ivor I thought one of the challengers was running the set-up and Drew knew of one
DaveBishop wrote:Thanks Ivor I thought one of the challengers was running the set-up and Drew knew of one
I can find out tomorrow, it is a holiday here today and everyone is closed.
If someone doesn't post I will find out :thumbright:
DaveBishop
Thanks Drew I knew someone would know its that kind of club
Cheers Dave
Matt
Post by Matt »
found some ( well written and detailed ) installation instructions here
http://www.edelbrock.com/automotive_new ... 3000.shtml
specifies an 'hei' coil but isn't any more specific.
I'm using the FAST EZ-efi which is completely different - it's just a fuelling system with no control over ignition.
cheers
Matt
DaveBishop
Hi Matt thanks
I do have the installation instructions but as you said all they state is that you use a 'hei' coil. I just wanted to know what other people were using.
Cheers Dave
I would use a HEI coil anyway along with a HEI module or MSD system. The HEI coil will work without a ballast resistor and deliver more energy.
DaveBishop
Thanks Dave
As you see from the attachment the kit comes with everything but the coil and whenever I ring someone for a 'hei' coil they don't seam to know what I am talking about.
Cheers Dave
DaveBishop
Sorry didn't attach to big but the kit as everything ECU, distributor, ignition amplifier etc. everything but the coil
This might help as it has a bit on the coil.
http://www.designed2drive.com/
DaveBishop
Hi Dave
Thanks for that I always thought that the hei coil was in the distributor cap but the kit comes with a Mallory distributor and as a connection for a separate coil
Cheers Dave
So try searching for a E-Core coil rather than "HEI". They work better with computer controled systems as there is less electrical "noise".
DaveBishop
Hi Dave
Thanks mate that Mallory one looks right if is separate from the distributor and the connection look the same as the one that I have the distributor that come with the kit is a Mallory one
Cheers Dave
