splitting an auto trans from a motor
got an engine and trans sitting in the garage as 1 complete unit
its a Borg warner 35 trans of the aussie persuasion i.e has the same bands and friction material as those that went into heavy duty applications like taxis stonger than a jag triumph rover one anyway
somebody wanted a 35 didn't they? £50 i have no need or desire
what do i need to do to split them apart, apart from the obvious removal of the bellhousing bolts
does the converter just slot into the trans?
or do i have to crane the thing into the air, get underneath and undo the flex plate so that the converter stays in place
i.e is the converter bolted to the transmision in some way
i know nout about this stuff never having owned anything other than a go-ped that had a torque converter (and it was a right Bananarama! to get of when it cracked)
will oil come out?
will oil come out?
- Dave-R
If you undo the bell housing bolts and just pull the trans apart the converter will just stay fixed to the flex plate and crank.
BUT!
There is a danger of damaging the pump on the front of the trans or the converter itself as the neck of the converter slides into the pump and the input shaft of the trans slides up the inside of the converter neck and engages inside the converter.
So always take the inspection plate off the bottom of the bell housing and remove the 4 bolts holding the converter to the flex plate. Then the engine and trans will separate, leaving the converter engaged in the trans.
BUT!
Mmm so shouldn't have put the crane way
if i roll it onto its side its not getting back onto the trolley again without the help fo 4 strong young fellas
or indeed a crane
converter bolts undone if I can turn over the motor MMMM
fill it with oil and hit it with the starter....maybe
or i just unto the bellhouing and spin it....MMmm it bolts on to both bits
I'll have a crack at the wekeend
or indeed a crane
Hi Dave999.
I just had a look at the VH service manual for the hemi 6 auto.
Just like Dave said.
No surprises involved, just like a V8.
One thing that may help so the converter does not slip off the input shaft as you are separating the auto from the engine is to use a C clamp or similar on the bell housing so the converter stays inside the bell housing.
