Its no yoke
AllKiller
Its no yoke
Post by AllKiller »
Paul with the Hurst a like dodge, has snapped a tap of in the axle yoke whilel drilling out to go bigger bolts and girdle, can you take the pinion out and put it back without dialling it back in for mesh ???
ALL KILLER NO FILLER
AllKiller
Post by AllKiller »
And how the hell do you get a tap out???
Spark erosion I'm advised but expensive
Yes take the yoke off but you will have to re-set the bearing preload when you re-install it. That will be shims or a crush sleeve depending on type.
ANTON
Post by ANTON »
If it has a solid pinion bear sleeve and not a crush sleeve then you can remove it. I have a friend who is a tool maker and he has a spark eroder
and is good on price as long as its cash. To spark erode the yoke will have to come off as the machine is not big enough for a complete diff.
AllKiller
Post by AllKiller »
Cheers Anton, what's your number please
A new yoke may be cheaper.......
AllKiller
Post by AllKiller »
Did think of that pete...its just time really...and lack of
AllKiller
Post by AllKiller »
I hope it's not the Moroso aluminium girdles, they are more failure prone than the stock straps believe it or not, there was a thread about them on moparts a while back. When I tried them years ago, they hit the prop yoke on full suspension travel :roll: Small U bolts are the best solution.
Mick70RR
Post by Mick70RR »
I broke a tap the weekend, got it out with a hammer and punch, just kept hitting it to shatter the tap and picking the pieces out.
Now I think about it, it was a drill not a tap that I broke. It was deep in the hole and jammed but I got it out in bits.
AllKiller
Post by AllKiller »
We considered that or similar Mick use a Hydraulic press to Bananarama! until it shattered or the thread gave way
andyrob
Post by andyrob »
spark erode is the way forward
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
Green68
Post by Green68 »
Hi Killer,
Yoke has no effect on mesh, just preload.
741 diff and 742 diff is ok to remove and replace.
489 needs a complete rebuild to replace the crush sleeve.
Bacca has yokes if you desparate?
Paul500
