Is the angle the same as SS springs????
Do you loose the pinion snubber???
Caltracs ,,,, pinion angle???
- pete walton
- pete walton
- Jon Connolly
I left my pinion snubber on when I put Caltracs on the Valiant ... I know the theory is take it off
I also locked my front suspension travel out at around 3 1/2" ... Again the theory was 5" of travel
The only real way of knowing is get it to the track week after week and see what works on your car with your driving style
When you set the preload be in there yourself at race weight ( fuel race suit etc ) ... I set mine 3 turns of the flat
Best of luck
Best of luck
- s6301096_335.jpg (48.86 KiB) Viewed 918 times
- s6300777_210.jpg (57.62 KiB) Viewed 918 times
- mopar_mark
