Clearance issues 70 Dart
Dart Vader
Post by Dart Vader »
Having put the 8.75 in, Rallye wheels and the BF Goodrichs on I dont think I've enough clearnance between the tyre and the rear arches
Tyres are 245/65/R15's, I can only get a pencil width at best between the arches and wheels
I presume this is too little.........the engine isnt in yet so its is sitting on its back end a bit and I was going to raise the rear end shackles by two or three inches so I guess this will create more space.
However if its not I'm going to have to down size the tyres to 235/60/R15
Will this extra 10mm be worthwhile or should I go smaller again?
Anyone done this swap if so what size tyres did fit?
Vader
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Dart Vader
bump
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Roll or cut the wheel arch lips.
Adrian Worman
Post by Adrian Worman »
Have you got a lot of space behind the wheel? Seems a bit tight for just a 245 so I wondered if the offset was wrong?
Jesus built my hot rod
72 Challenger
65 Barracuda
Dave wrote:Roll or cut the wheel arch lips.
That would be my thought, before shelling out on new tyres . . .
PaulR
Post by PaulR »
This thread on A bodies only may have some info that may help on max sizes.
http://www.forabodiesonly.com/mopar/sho ... p?t=192533
Dart Vader
PaulR wrote:This thread on A bodies only may have some info that may help on max sizes.
Thats very helpful, cheers guys, not sure of the back spacing.
May just have to suck it and see, if needs be then it'll be a tyre change I guess
Cheers fellas
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
How did you get on with this Vader?
Just hit the same problem :roll: :roll: really Bananarama! off!!! :evil: :evil:
Jeff
Post by Jeff »
I have a roller here..... What a great tool it is! Bit addictive though!
Dart Vader
Blimey Jeff, going though all the old stuff !
Fixed it by going to smaller tyres in the end !
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Jeff
Post by Jeff »
Oops. Sorry.
GJUK
Post by GJUK »
mini tub it :D
On a more serious note, I have just about got this side on the rear but they were tight on mine also (68 dart)
If you are happy with the wheels and tyres I would look at cutting or folding back the lip on the arch. You can do it without cracking the paint if you are REAL careful. That said a bit of paint would cost only £50 for both sides I expect if you make a mess.
roll those arches :thumbright: make em fit
Dart Vader
Thought about that but didn't have the heart or balls to try it. My panels are way too good to do that !
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
terryr
Post by terryr »
Dont do it.if you have nice arches leave them alone.enough wheel arch butchery has happened to darts over the years.rolling them creates rust traps
Its time to stop all that bodgery :cry:
