Quick fire pop quiz -
Whats the difference between disc brake spindles and drum brake spindles ?
Spindles - whats the difference ?
- Adrian Worman
- Adrian Worman
Yep I think you're right, I was thinking of the difference for installing the later large rotors............. check this article out tho Morgan, it's got excellent info;
http://www.moparaction.com/Tech/archive/disc-main.html
Jesus built my hot rod
72 Challenger
65 Barracuda
72 Challenger
65 Barracuda
A Drum spindle is symmetrical.
A Disc spindle has cast in lugs to take the caliper brackets/carriers.
They can be hung in front of, or behind the wheel depending on which way round you "swap" the spindles on the car. I always opt for "Behind" but this usually means you need to use Dash hoses instead of OEM style rubber ones.
The Caliper brackets/carriers are interchangeable to take larger discs - the bolt holes are in the same place.
'70 and '71-'74 "E" Body Disc spindles have different size bearings. They take different discs and are not inter-changeable.
Be VERY careful in doing a brake swap without lots of research.
Thanks chaps - as always.
Just chin scratching as usual. Even the 'all in one' kits are for 'drum spindle'. Just doing some research really. There do seem to be a disproportionally high number of options. Its all part of the big pie-in-the-sky plan...
