Suregrip
big block
Suregrip
Post by big block »
Can anbody tell me, if you can tell me if an axle is fitted with a suregrip with out dismantling.
Ive heard that if you turn an axle one way and the other turns the other way its an open axle is this correct ?
thanks in advance guys :thumbright: Pete
challenger
Post by challenger »
you are correct pete, in fact with an open you can hold one side and spin the other, time you got a spool in there anyway :D
keep it mopar !
big block
Post by big block »
Yes, I think I worded that wrongly Jim,I know if they turn opposite directions its an open diff. The real question is would a suregrip turn the same direction as the other side :thumbright:
and yes Jim may be time for a detroit locker, anybody got one going cheap :D dont know about a spool on the street anybody running one with no problems ?
Didn't the sure grips come with a small metal tag on them ?????
Easily broke off though I would imagine
Gary :thumbright:
Adrian Worman
Post by Adrian Worman »
Don't forget if they are proper shagged out they won't even hold up to a hold one side and turn test, especially the cone type
Jesus built my hot rod
72 Challenger
65 Barracuda
challenger
big block wrote:Yes, I think I worded that wrongly Jim,I know if they turn opposite directions its an open diff. The real question is would a suregrip turn the same direction as the other side :thumbright:
all the ones ive worked with pete turn together, if they dont its either knackered or open diff, i guess you do get a certain amount of slip but not enough to turn one side without the other
keep it mopar !
Think Gary is right there, should have a small tag on one of the cover bolts something like the ones in these pics,
Cheers Steve :read2:
suregrip tag 2.jpg (18.37 KiB) Viewed 1165 times
suregrip tag 1.jpg (3.49 KiB) Viewed 1165 times
no,,,,,,,,,,,,,,,
all mopar 8 3/4 diffs got a tag to let you know what ratio it has, not if its a suregrip,
ANTON
Post by ANTON »
if it has a suregrip in it you wont be able to turn the wheel as you have to overcome the suregrip to turn the wheel.
Open diff jack one side up and leave one wheel on the floor and the one off the floor you will be able to turn
Adrian Worman
So long as its working ok......... ;)
72 Challenger
65 Barracuda
ANTON
Post by ANTON »
Adrian Worman wrote:So long as its working ok......... ;)
If its not working then you have a very expensive open diff. :lol: :thumbright:
Most will turn if they are not brand new and turn both wheels. But they will be heavy to turn. Same if you only jack up one wheel. It will turn but will be very hard to do so.
These and LIMITED slip diffs. Not locked.
Only ever seen any kind of tag still on a diff once I can remember. It may have been there in the 60s and 70s but don't expect to find one after all these years unless the car has been in a barn since they walked on the moon.
big block
Post by big block »
Mine went with an almighty bang leaving the startline at the nats, thought broken halfshaft or propshaft, but still drives.but locked up like a spool!with no backlash on pinion what so ever! Not pulled it out yet but I assume it's Bananarama! .
Found an axle at right money but don't know it's a sure grip hence the question :thumbright:
the spider gears might have smashed and jamed it into a locked state or welded themselves to the cross shaft
if they have there will be bits floating about would be shame to put dents in your ring gear teeth as well
big block
Post by big block »
No, not driving it Dave. Just need to find some time to pull it out, but I don't think you can repair them anyway. Probably need to put an ad in wanted section :thumbright:
