I've got an aftermarket Disk/drum master cylinder but read somewhere
I need to change booster,also said to change metering block for proportioning valve. Any info greatly appreciated
jerry wrote:Dave can I do away with the metering block and run straight out of the master cylinder to the rear and out of the cylinder to a tee then off to front discs
Agreed, dont Bananarama! with your brakes too much, they are usefulautofetish wrote:jerry wrote:Dave can I do away with the metering block and run straight out of the master cylinder to the rear and out of the cylinder to a tee then off to front discs
I would say no as this is a fail safe until so in front pop a leak you still have rears.
What break set up did you have and what you installing as i have the same question at the moment
jerry wrote: the master cylinder is an inline tube one i got off an MMA member a while ago.
