sparkplugs for 440
RoelB
sparkplugs for 440
Post by RoelB »
What would be a good plug to use on my RoadRunner
Stock motor with orginal Holley.
Thanks!!
AllKiller
Post by AllKiller »
I swear by the NGK BPR6S Or the Iridium XR5
But no doubt there will be some Champion fans RJ12YC
ALL KILLER NO FILLER
Les Szabo
Post by Les Szabo »
yep NGK all the way :thumbright:
RoelB
Post by RoelB »
fine by me, thanks!!
What makes one plug better than another plug gents??? I appreciate some run hotter than others etc but how do you know what is a good plug for your car? I use Autolite copper core 85s in my completely stock 383 4bbl but only because thats what I get when I ask for a set at the place where I get my service parts.....I dont have any probs with them but should I put more thought into it???? :read2: :read2:
Cheers, Steve
Quiffy's right on the money there!!! ;)
Guy
Post by Guy »
Pete wrote:Quiffy's right on the money there!!! ;)
Yep XR5's here :thumbright:
GTXJim
Post by GTXJim »
So what would be the best NGK for an indy headed motor with 10.75:1 compression??
Hell Yeah!! I'm a Redneck
I ran the NGK's in a 12.2:1 compresion motor with no issue.
Can't remember if I changed the heat range over the 6s though............
Bryan S
Post by Bryan S »
GTXJim wrote:So what would be the best NGK for an indy headed motor with 10.75:1 compression??
NGK 6s
AllKiller
Post by AllKiller »
Jim
NGK R 5670-8 = 2nd coldest and probably will work the best with that compression, although the others will work well
NGK BP7 ES
NGK 7173.
Iron heads need a hotter range plug than an aluminum
Last number on NGKs is the heat range lower the number the hotter the range
Champions are other way round higher number is higher heat range
But that means how quickly they dissipate heat not how hot they run
NGK 7 street
8+ racing
NGK even do projected and Non projected tip for use with large amounts of Drugs :thumbright:
AllKiller
Post by AllKiller »
Steve wrote:What makes one plug better than another plug gents??? I appreciate some run hotter than others etc but how do you know what is a good plug for your car? I use Autolite copper core 85s in my completely stock 383 4bbl but only because thats what I get when I ask for a set at the place where I get my service parts.....I dont have any probs with them but should I put more thought into it???? :read2: :read2:
Cheers, Steve
Autolite is a good plug...if its working with no probs stick with em
I just prefer NGKs....you wot really notice any seat of the pants difference Steve
But you might from Champs to NGKs, i did
TyreFryer
Post by TyreFryer »
Good reference info Steve, I'll make this a sticky.
Martin Walker
AllKiller
Post by AllKiller »
John
Post by John »
I`ve just found out I have champs
Time for a change I guess :?
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
