James Demon not James Dean
Demon James
Post by Demon James »
More of a "cosmetic work so far" build, certainly not in the total rebuild league (yet ;) ) But I thought I'd better start a propper thread on my car as I have loads of pics I've taken so far for my own refference on the little projects so far. So in no particular order.............this is a rear floor trim i had to make as the drivers side was missing when I got the car. At least I had one to copy as a mirror image :thumbright: I should also point out that I formed it on a home made sheet bender that my Dad made at Barnfield College (course for car restoration :thumbright: ) now thats a college course I'd always turn up to :lol:
Rear floor trim 4.jpg (60.44 KiB) Viewed 2035 times
Rear floor trim 3.jpg (90.79 KiB) Viewed 2035 times
Rear floor trim 2.jpg (67.14 KiB) Viewed 2035 times
Rear floor trim 1.jpg (77.94 KiB) Viewed 2035 times
Demon James
;) My offering is the one on the left without the MOPAR plum crazy overspray :roll: :lol:
Demon James
Oh and this is how pleased I was when I picked the car up last year :lol:
Happy me! (Small).JPG (73.04 KiB) Viewed 2032 times
Demon James
I cant find the "before" pics of the grille and light surrounds but it was pretty tired, I repaired a couple of broken brackets with alooominum home made affaires then gave everything a thorough clean and fresh paint.
Front Grille removed.jpg (63.4 KiB) Viewed 2020 times
Front Grille Refurb 2.jpg (114.48 KiB) Viewed 2020 times
Front Grille Refurb 1.jpg (110.94 KiB) Viewed 2020 times
Demon James
Nearly done :)
Front grille completed.jpg (99.42 KiB) Viewed 2017 times
Nice car, James .Looks just right!
Demon James
:iagree: :lol: :lol:
Found a floor shifter kit at the restoration show last month which surprised me as I wanted one but thats not why I went and didn't expect this. All the kit was there, all bags sealed and instructions (even stickers which along with the spoiler will make the car even QUICKER!! now :lol: )
I re-trimmed the horrid plastic housing to match the carpet and it looks much better. Lovin how the car drives now, much more fun :thumbright: Just need to work out how to remove the column shift lever now with taking the steering apart if poss.
Took a couple of hours to fit with two of us :working: so it was a nice little job with great results :)
Disc conversion next?? :? but I need bigger wheels though as I only have 14's and like them so that may be a while.
Floor shifter.jpg (82.36 KiB) Viewed 1908 times
Nice car, love Demons in purple :thumbright:
Good bit of metalworking too!
terryr
Post by terryr »
superb,partial to a demon myself,,,
Adrian Worman
Post by Adrian Worman »
terryr wrote:superb,partial to a demon myself,,,
Bananarama! me Terry that made me larf till me ribs hurt :thumbright:
Jesus built my hot rod
72 Challenger
65 Barracuda
Demon James
Finally decided to see about getting the temp and fuel gauges working (to a fashion :) )
Inside the instrument cluster had gone a pale yellow so this has been painted with shiny alooominum....um paint which has improved the dash lighting.
I raided my supply of model paints for some day-glo orange which works really well on the needles, I also used plastic polish on the dial windows and I'm pleased with the result, no more cloudy gauges :thumbright:
The multi-pin plug and socket on the back or rather the tracks on the circuit board where the pins are soldered to them seem to be a major source of my lighting and gauge issues.
After a good clean, de-solder and re-solder and also running a clean ground wire from the dash cluster to the ground block I've fitted I now have moving gauges for temp and fuel :woohoo: How accurate remains to be seen but I'm very happy so far :D
I also cleaned out the light switch assembly and the dimmer works brilliantly now 8-)
I then took the opportunity to clean all the "fluff" from behind the steering wheel that had built up in the turn signal switches :pale: bluurrgh grim.
Just on the lookout for a donor volt meter to graft into the ammeter window since I've bypassed it before it burns the dash.
All good, :thumbright: another little job ticked off :)
Dash Recon 006 (Medium).jpg (81.22 KiB) Viewed 1782 times
Dash Recon 005 (Medium).jpg (69.79 KiB) Viewed 1782 times
Dash Recon 004 (Medium).jpg (74.95 KiB) Viewed 1782 times
Dash Recon 003 (Medium).jpg (92.65 KiB) Viewed 1782 times
Demon James
:lol: :lol: :lol: :lol: :lol: Must have missed the photo Tel, not posted on this thread since then!!! Propper funny :lol: :lol:
Adrian Worman
Good effort mate :thumbright: ........... only a month away now :D
72 Challenger
65 Barracuda
V8 Sam
Post by V8 Sam »
Need to I that to my dash!!
bruvmopar
Post by bruvmopar »
Great work James, car looks fantastic 8-) 8-) 8-) :thumbright:
1969 Dodge Coronet SuperBee.
1968 Dodge Charger.
1969 Mercury Marquis 2-dr HT.
1994 Ford Mustang GT V8
2003 Audi A4 TDI Estate
2005 Ford Transit
