Rear Gear,s????
pete walton
Rear Gear,s????
Post by pete walton »
Spoke to Jimbo the other day about the formula for working out how tall your rear gear,s should be,,,,,,were is it Jim????,,,,,i can,t find it???
GTXJim
Post by GTXJim »
Ive emailed you mate..
Hell Yeah!! I'm a Redneck
pete walton
Nice one Jim,,, if my moter is making 700ish hp ,crossing the line at 6750rpm with a 32 inch rear tyre ,,,i should be running 9.11 at 145mph :D ....surprising thing is my rear gears need to be 4. 41 ish ,,,at the moment they are 4.88....that explains why i am nosing over about 300 ft out.......In a perfect world hey :thumbright:
Mick
Post by Mick »
If it's any help Pete, i turn 6700 through the line with a 31" tyre and 4.56 gears. So i would say that's what you need.
Mick
What does the car weigh?
If it is nice and light you may be able to get away with taller gears to either keep the rpm down or maybe attain higher mph!!!
Mick wrote:If it's any help Pete, i turn 6700 through the line with a 31" tyre and 4.56 gears. So i would say that's what you need.
Mick
Agree.
AllKiller
Post by AllKiller »
Got some 5.13s Pete cheap £50 taller tyre and away you go...certainly get you off the line ;)
ALL KILLER NO FILLER
Six-pack Speedshop
Post by Six-pack Speedshop »
Use the biggest tire you can fit and gear it accordingly I would say.
Les Szabo
Post by Les Szabo »
700hp at 3000lb all in? with a 4.56 gear
60 Foot E.T. : 1.32
1/8 Mile E.T. : 5.97
1/8 Mile Trap Speed : 113.86
1/4 Mile E.T. : 9.46
1/4 Mile Trap Speed : 142
1/4 Mile Trap RPM : 6,786+ a bit of slip?
with 4.88
60 Foot E.T. : 1.32
1/4 Mile Trap RPM : 7,262+ slip
why are you nosing over?...Indy Heads etc?.....that should pull well into the 7000rpms with a good cam/carb jetting sorted Pete...
________
this is an example of what Mick runs at 600hp
60 Foot E.T. : 1.41
1/8 Mile E.T. : 6.39
1/8 Mile Trap Speed : 106.41
1/4 Mile E.T. : 10.12
1/4 Mile Trap Speed : 132
1/4 Mile Trap RPM : 6,547+slip
more or less spot on with this calc cept for his mph is a bit down
Les
Pete.S
Post by Pete.S »
I'd go 4.56
