Oil Primer
pete walton
Oil Primer
Post by pete walton »
if you run a external line system Check this out ,,,no more taking the dizzy out.....external oil primer....thats on me shopping list
Mick
Post by Mick »
If you keep the lines higher than the pump, that stops drainback.
Wish i'd known that years ago, when i had an external system. I used to have to pull the distributor out and spin the pump drive in reverse, to get the oil pressure up, everytime i took it to the track.
Nice idea though.
Mick
I have external oiling and no drain back / need to prime for the reasons Mick stated :thumbright:
