Fitting Windscreen to 68 Charger
DaveD
Post by DaveD »
Hello some advice needed please. About to fit the windscreen to the Charger and I have purchased the gasket from Yearone. Does anyone know if bead lock is needed for this model?
I have been informed on good authority that B bodies do not require bead lock; as the gasket has a 'self locking strip'. However the gasket (which is labelled correctly for the car and fits) appears to have a groove for bead.
Is this groove for something else?
Any tips / advice or directions to a website very welcome.
Thanks Dave
terryr
Post by terryr »
no lock strip on a charger,i think once you have your screen trim on the lip on it should sit in the groove,dont forget to use the butyl tape if you can ,as this really does help to seal the screen
When we put the front screen in the Barracuda with a new rubber it leaked like a seive.
Had to re-do it all again annd use Silicon between the rubber and the steel to stop the drips................
terryr
Post by terryr »
the tape swells with contact with water and seals holes
Ah Ha! :thumbright:
terryr
Post by terryr »
here ya go ,different car ,but you get the idea
http://www.moparmusclemagazine.com/proj ... to_01.html
DaveD
Windscreen
Post by DaveD »
Thank you - please keep the tips / ideas / links flowing.
Lots of that silicone grease and don't use a screwdriver! Just as I was edging the last corner in...ping! :oops:
Is the grove for the chrome trim thing
Below is a vid on a headlining replace but they take the glass out might help
Keep this post up dated with what parts and how you did it
I'm due in a few weeks to do the same
steveo
Post by steveo »
what the other guys say :thumbright:
also
make sure you have & fit the correct revel moulding clips , put a dob of grease inside the clip , will help/ be easier to engage the stainless trim , run a bead of non hardening glass sealer , i always used Arbomast , where the purple lines are in below pictures , make sure the windshield gasket is engaged with the three metal tabs in third picture , then fit gasket ,
once fitted, with a brush etc & washing up liquid , lightly coat the edge of the channel on the gasket where the glass is going to slide into. , if its the original glass , they well heavy , put a blanket on the hood with big piece of card board & or a few large cushions , to lay the glass on , while getting into position , with a helper , with one person each side slide the glass up so it engages into the top edge of the gasket channel first , then while helper is stopping the glass sliding down , carefully lift the rubber over the the glass , so it droppes into the channel & adding a bit of pressure as you go , use plastic filler spreaders & or windshield push sticks , to do this , all the while your helper is pushing the glass up into the top channel . (( never push middle ))
when fitted , give the glass a few slap type pushes with the palm of your hand , around the edges of the glass towards the rubber , ( don't go mad , ) to make sure every thing is seated correctaly & aligned ,
clip the seam on the gasket together , using plastic filler spreader or push stick , ,
then pump arbo sealer down between the glass & windshield rubber , will need , the correct flat nozzel or a small thin one , don't go mad , soon as you move the sealer gun with tip along the squishes the excess sealer out , good idea so spray the glass with glass cleaner before you do this , makes clean up of excess sealer easy ,
DaveD
Fitting windscreen
Post by DaveD »
I am very grateful to everyone for the contributions and photos provided; they are very helpful.
One more question if I may to satisfy the niggling doubt.
What's the 'spare' channel on the gasket for if no locking strip is needed?
Thank you
steveo
Post by steveo »
there is no spare channel ,
& there is no seperate locking strip like on some cars ,
thats the open locking strip actually in the rubber , it clips in on its self , when its open , it makes the gasket flexable & more malleable so you can slide the glass under & into the top channel plus leaver the rubber over the glass ,
*** remember its not a string in glass **** you fit the gasket first to the car !!!!!!
once the glass is fitted , you then close this strip up this gives it rigidity & strength to the edge of rubber over the glass , if it did not have this opening & closing channel & was solid , the rubber would be to rigid/ hard to lift over the glass when fitting , or at the other end of the spectrum , if it was soft & malleable , with out a locking strip for strength , worse case when you slam the door / driving with windows down /internal air pressure in the car could pop the screen , it just simply presses together after the glass is installed , might need a bit more washing up liquid , & bit of work with a plastic spreader ,
it sounds far more complicated than it is ,
DaveD
Windscreen
Post by DaveD »
Steveo
Thanks very much for your reply.
got to be a sticky please
Pun intended?
