Posts: 7679 Joined: Wed Jun 27, 12 6:57 pm
Post
by Mossy68 » Wed Jan 30, 13 6:31 pm
Just a quick one.
My new headers have arrived ( Hedman ).
Will giving them a coat of heat proof paint before I fit them be worth it ?
I understand that they come "blown over " in paint for storage.
So would this coat have to be removed prior to painting ?
Thanks. Gary
Posts: 24752 Joined: Sun Apr 18, 04 11:23 pm
Post
by Dave-R » Wed Jan 30, 13 7:14 pm
Don't bother. It will burn/rust off in no time.
If you didn't want them to look rusty you should have gone for the ceramic coated versions. That is the only way to keep them nice.
Post
by Mossy68 » Wed Jan 30, 13 7:20 pm
Just what I was wondering.
Cheers Dave
shovelheadrob
Posts: 959 Joined: Tue Sep 18, 12 10:27 am
Post
by shovelheadrob » Wed Jan 30, 13 7:31 pm
I used to get mine aluminium sprayed, they blast them first, then they are coated with a blow torch with a wire feed, lasts for years. I'll be getting the fenderwells on the Demon done just as soon as I get them back from being repaired. I use a local place,
http://www.blasters.co.uk/
Posts: 22108 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Wed Jan 30, 13 7:38 pm
There is also a place near Buntingford that does the ali spraying.
Also a place near Oundle - Rob: did you use that company???
Cheers.
shovelheadrob
Post
by shovelheadrob » Wed Jan 30, 13 7:56 pm
No Pete, I use the one in the link, I used to do a lot of business with them back in the 90's when I was wrenching for a living. Went to see them just after I got the Demon & the guy who runs it still remembered me even though I hadn't seen him for 15 years at least. Don't know if that's good or bad
they are a big company but still cater for the small jobs.
Philth
Posts: 857 Joined: Sun Apr 18, 04 10:48 pm
Post
by Philth » Wed Jan 30, 13 9:50 pm
Gary - break out the Gibbs.....
Sorry mate - couldn't resist!!
1973 Dodge Challenger
MMA 616
Post
by Mossy68 » Wed Jan 30, 13 9:54 pm
Philth wrote: Gary - break out the Gibbs.....
Blimey. Forgot about Gibbs !!!!!!
But I've run out cleaning household objects
Thanks for advise guys
Post
by Pete » Wed Jan 30, 13 10:54 pm
I had the Dart's Fenderwell Headers and the 'Cudas Headman headers Aluminium sprayed.
Good "half way house" solution compared to Ceramic coating, but much better than painting with VHT paint............
Posts: 5599 Joined: Sat May 21, 11 6:43 am
Post
by autofetish » Thu Jan 31, 13 7:15 am
what about heat wrap with the bandage stuff
is that any good
Post
by Pete » Thu Jan 31, 13 8:44 am
autofetish wrote: what about heat wrap with the bandage stuff
is that any good
Bananarama!. End of.
Posts: 6738 Joined: Fri Jul 14, 06 8:01 pm
Post
by mopar_mark » Thu Jan 31, 13 8:49 am
Pete wrote: autofetish wrote: what about heat wrap with the bandage stuff
is that any good
Header wrap works in the fact it helps retain heat & assists exhaust gases, the down side is that it promotes corrosion of the headers
Post
by Dave-R » Thu Jan 31, 13 8:51 am
Header wrap completely destroyed my headers in just two thousand miles of driving.
Post
by Pete » Thu Jan 31, 13 8:58 am
Dave wrote: Header wrap completely destroyed my headers in just two thousand miles of driving.
Post
by mopar_mark » Thu Jan 31, 13 3:45 pm
I have been researching all kinds of Header coatings for my system on the Cuda.
Zirtec were the best I could find for my needs, a key point for me was heat reduction & Zirtec offered up to a proven 30% heat reduction.
