The Coronet has developed a noise at the back end. The only way I can describe it is like a bearing 'hum' with a train on a track mixed in if that makes sense ?
It happens now and again and lasts 3-4 seconds. Doesn't seem to be any cause ie cornering or accelerating etc. it will sit on a motorway for miles without a sound.
The brakes and bearings were all checked prior to mot and all seemed fine apart from some new self adjusters.
The axle (8 3/4 sure grip ) was low on oil and so was topped up with correct oil although I didn't add any friction enhancer.
Doesn't 'chatter ' cornering from a start.
Any ideas ????
Cheers. Gary
