what carb do you use
hi all, what type of carb do you use on your mopar? and which carbs do you reckon are the best, holley/edelbrock/other?
Trev, Holleys are fine... if you don't mind:-
having to drain the float bowls every time you want to change jets
replacing the float bowl gaskets every time you want to change jets
losing/tearing the little rubber O-rings on the fuel transfer tube
fuel spraying all over the engine when you adjust the float bowl levels
replacing the power valve if the motor backfires
...get an Edelbrock Performer
