Viper brakes
AllKiller
Viper brakes
Post by AllKiller »
How do the pads come out front calipers on a Viper ??
cant suss it
Its the Pins what or how do they come out ??
ALL KILLER NO FILLER
blonde moment ?
Knock out pins with drift
Then pad will come out the top.
You may find you pads are slightly stuck on piston try a wiggle with screw driver.
If on car push back piston and pad with screwdriver first
to replace just drop in
ps. check my build pictures to make sure you have the correct pads ;)
shovelheadrob
Post by shovelheadrob »
I'm fairly sure that they puch out from the outside/in. They have an interference fit sleeve around the inner end of the pin. They are basically Brembos aren't they?
what he said perfect
AllKiller
Post by AllKiller »
Cheers guy didnt want to bust anything...so precaution is better than a big bill or looking for another caliper.
Got mint calipers with new red stuffs Will.
Yes they are basically Brembos James
