Clutch ideas please!
Clutch let go under a bit of moderate abuse today :?
I don't think it's gonna last long on the strip.
I'm sure it's down to all the trans fluid that got dumped on it when the front seal was leaking.
So I reckon minimum I'll need to replace the friction plate.
Ideally I'd like to upgrade but I don't think finances will allow.
Anyone got a decent 18-spline clutch going cheap? :help:
727 will cure your ills ;) Forget manual,just not up to it.
Adrian Worman
Post by Adrian Worman »
just get a new centreplate and scutchbrite the pressure plate mate, it'll be fine ;) Real Steel have plates in stock
Jesus built my hot rod
72 Challenger
65 Barracuda
latil wrote:727 will cure your ills ;) Forget manual,just not up to it.
:P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P :P
Cheers Ade, hopefully that'll do the trick!
6923-05 MOPAR 1955-1985 V8 ; Small Diameter Flywheel. 1-3/16 x 18 Input $1125.00
:shock: Nice, maybe one day...
Option 1
steep the friction plate in persil automatic at 37 * centigrade
organic enzymes like to eat organic oils
works with brake shoes might work with clutch plate.
another option
http://www.npcperformance.com.au/
these guys made me a light weight flyhweel and a clutch
clutch cover based on re built re sprung exedy ford v8 item
and set to balance clamping force peddle effort againts the friction material used
cost about £450 and £100 to send via australia post
if you tell them what you want they will build it.
MIGHT be less than a special US one and custom made for YOUR application
then again it might cost a fortune i got mine 4 years ago
ratebuster 1 pence per minute phone call and have a chat
then again if they do it wrong....
dave
db wrote:6923-05 MOPAR 1955-1985 V8 ; Small Diameter Flywheel. 1-3/16 x 18 Input $1125.00
Well when you insist of trying to use manual gear boxes for drag racing you have to realise that, no matter how strong you make the drivetrain, the clutch is always going to be a weak point.
Think about it.
You are using only surface friction to transfer hundreds of horsepower to the rear wheels.
Which do you think has the chance of breaking loose first;
1) The massive sticky rear tyres with the weight of the car pressing them down onto a sticky prepped dragstrip?
2) Or the clutch plate pressed against a smooth steel flywheel by a few little springs?
Not exactly a fair fight is it? :lol:
Think about it.
:P :P :P :P :P :P :P ;)
Adrian Worman wrote:just get a new centreplate and scutchbrite the pressure plate mate, it'll be fine ;) Real Steel have plates in stock
Not for 18-spline though, of course :roll:
AllKiller
Post by AllKiller »
Dave wrote:[Which do you think has the chance of breaking loose first;
Great explanation...love it :lol:
ALL KILLER NO FILLER
Got Chris at WASP on the case.
Watch this space... :thumbright:
If I catch you with that car laid up and out of action at the Nats I am going to be very cross with you! :lol:
But not suprised... :D
Dave wrote:If I catch you with that car laid up and out of action at the Nats I am going to be very cross with you! :lol:
I've persuaded quite a few mates to come along to watch... there may be a long queue :shock: I'm thinking of the scene from Airplane... :violent1: :violent3: :wack: :deadski:
70_charger
Post by 70_charger »
I cured my cltuch problems by fitting tci 727 race box, more consistency and lower et as no gear change lag
