Hydraulic lifters
Hydraulic lifters
Having real problems with my 383 repaired the broken rocker adjuster, now seem to have loads of valve train noise. Taken cam out and all seems well any way of checking lifters could do with advice here as I just seem to be going round in circles at great cost
Just a few thoughts Steve.
Have you got a high lift cam in there so you may be getting spring binding?..hence the broken adjuster and you may have bent a few pushrods.
If that's all OK, I know it sounds silly, but have the lifters got plenty of oil getting to them? When they are empty, you can push the piston down easily, when they are pumped up, they are nearly solid.
Sorry If I'm stating the obvious Steve, but if you like, I'll drop around a good set of standard 383 hydraulic lifters, if you want to give 'em a try, I'm only half an hour away.
Its only a mild cam so pretty sure adjuster broke through old age. Thanks for the offer Ivor thats very generous got the shells out at moment but as soon as my mini starter arrives might take you up on that thanks. Terry R Jimmy Hibbard built the engine so anything is possible you know what these ford fanatics are like
