Body/ tool guys, best spot weld cutter?
Need recommendations for a good spot weld cutter. I had a snap on one for years which was great, but someone borrowed it and lost it
Snap on don't seem to do them any more, so I've been struggling with Draper, which is all I can get and they are absolute rubbish. So, what can you recommend and where can I get it?
- sidewaysjas
spot weld cutter
Hi Blue
'Frosts' do a reasonable one, its the type with the changeable cutter head and spring loaded point. Seem to cut okay but doesn't last too long so get a couple.
www.frost.co.uk
Jas
www.frost.co.uk
Jas
'wouldn't change if I could'
Blue, try these old son, I've drilled nearly two hundred spot welds with one pof these (I bought eight, just in casze) and the first one's still cutting!
Quick, easy and a bargain
http://www.ebay.co.uk/itm/8-0MM-SPOT-WE ... 301377889?
- autofetish
This is what I use there greatIvor wrote:Blue, try these old son, I've drilled nearly two hundred spot welds with one pof these (I bought eight, just in casze) and the first one's still cutting!
Thats what i meant.Ivor wrote:Blue, try these old son, I've drilled nearly two hundred spot welds with one pof these (I bought eight, just in casze) and the first one's still cutting!
- Stu
Blue, I completely got the wrong end of the stick when you asked me about these the other day
As soon as I heard the word "weld" I automatically heard that you were looking for welding equipment.
Mark / Jerry is right, those Blair carbide bits get spoken of very highly, though I confess i've never used them. Note to self, listen better. It must have been the lack of beer...
Would an ordinary drill bit work if you ground the end down to the right shape?Pete.S wrote:As roger, I use the dormer drill bits on an air drill. Not getting spot bits too hot also extends bit life considerably
Also you can get 10 mm bits for some modern French cars, but I've found them handy on old yanks too due to inconsistent spot sizes
If you were very good at shaping and filing the end yes but wouldnt last long compared to a hardend heat treated dormer bit.
One of my old boss' s tried a few times to get the dormer bits re sharpened but they wernt the same lasted about three spot welds and were even worse on boron steels also if the centre pilot point isnt cut right the bit will walk across the panel
