727 cooling lines question
Dart Vader
Post by Dart Vader »
One of my two cooling lines has broken in the past and was bodged with a bit of rubber
My question is are they all the same across a bodies, b bodies?
Is it best just to replace them with some braided hose and run a separate cooler?
What are the fittings?
J
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Justin, different for different cars. I made some up using copper tube and the original fittings last time around. Used a separate trans oil cooler too.
Separate cooler is always a good insurance policy.
Don't use rubber, I have seen them blow off under pressure at the track :shock: :shock: :shock:
Underpants-filling time!!!
Dart Vader
Yeah, was more looking at replacing them
Defo a cooler, means I can use a spare b body rad I have
Will look at the copper pipe route
Cheers guys
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Adrian Worman
Post by Adrian Worman »
Don't use soft bendable copper, its too soft and you risk a stone or something flattening or worse cracking it.
Use some large diameter brake tubing ;)
Jesus built my hot rod
72 Challenger
65 Barracuda
shovelheadrob
Post by shovelheadrob »
The stuff you want is called kunifer or cunifer, I've seen it spelt both ways, it's a copper alloy. Available in various diameters.
With the proper reducers and adapters you should be able to use the factory lines and at the end use the said fittings ,with a braided hose run that to a cooler and back in line , that is what I have currently :thumbright:
