46RH overdrive / transmission query
- Jon Connolly
I have a 46RH transmission I am looking to use. It is not the later electronically driven box but the standard hydraulic 3 speed with electric overdrive. I have 2 questions.
1 - Can the electric overdrive be operated by a simple driver operated switch so it is either on or off ???
2 - Is overdrive a straight percentage of 3rd gear. i.e. if I had a 4 10 ring and pinion is overdrive 0.69 x 4.10 = 2.83 giving me an equivalent of a 2 83 gear when overdrive is engaged ??
Or have I got completely the wrong idea ?????????
Thanks in advance
Thanks in advance
- Cannonball
yes you can use a regular flick switch i think you may also need a switch for the lockup converter and a tip switch on brake or throttle to knock it back off you wont want it locked up as your slowing down,, no idea on the ratio but 3rd gear is 1 to 1 so its deff a overdrive ie 4th gear,
- Jon Connolly
Nice one Dunc
Be a bit quicker next time
( Specs say 3rd gear is 1 to 1 and overdrive is 0.69 which seemed alot to me ? )
Jon,
Wikipedia search shows od to be 0.69:1
Link to HodRod mag article
http://www.hotrod.com/howto/43323_mopar ... sion_swap/
PATC have quite a bit of info / parts on the A518/46RH trans
Chris
Chris
- Jon Connolly
Looks like it could be simple answer to the road legal strip car trade off.
Dave ... I was thinking it would be more like 15 - 20 percent not 31 percent ?
Thanks all
Thanks all
- Six-pack Speedshop
Yes it's a 31% so drops the revs nicely.
We are in the process of installing a new build (with bb bellhousing) one behind a Hemi and include a throttle positioner and pressure sensors to make it do the overdrive / lock up fully automatic. Still in the process of trying to set it perfect so no real world experiences to share yet.
These are nice transmissions.
- Jon Connolly
Nice one 6 pack ... I`ll let you do the research and let us know when you have it working correctlySix-pack Speedshop wrote:Yes it's a 31% so drops the revs nicely.
- Cannonball
i have built severall for the jensen boys and one fitted to a facel vega.
they are a 904 with lockup and overdrive . or 727 with lockup and overdrive, they also do a 48re that goes behing the cummins and the v10 mtr that is well upgraded
Interesting stuff.Cannonball wrote:i have built severall for the jensen boys and one fitted to a facel vega.
Do you have to cut the bellhousing off like you were using an ultrabell so you can get it to marry up with the back of the B R/B Block???
How much bhp and torque can it take???
- Cannonball
the customers purchased there own converters and the adapter kit for the small to big block patten i think some firm stateside may have cast the case to suit a b/rb not sure thoughPete wrote:Interesting stuff.Cannonball wrote:i have built severall for the jensen boys and one fitted to a facel vega.
Good thread:
http://www.dippy.org/forum2/index.php?topic=231.0
Adapters:
http://www.transmissioncenter.net/dodge.htm
#56XXX. Chrysler Big Block (361, 383, 400, 413, 426, 440) to Dodge Small Block 518 transmission. This is the adapter everybody is looking for. 6 bolt crank Cost $689.00, 8 bolt crank Cost $730.00
