I'll be bolting them on this weekend so I'll post up some piccies, plus a bearing adaptor that allows you to keep your drum or early disc spindles and still fit later rotors
E body brake upgrade
- Adrian Worman
I finally got the parts I need to fit the Killers slotted and grooved discs on my Chally.
Jesus built my hot rod
72 Challenger
65 Barracuda
72 Challenger
65 Barracuda
- Adrian Worman
Have more faith unkie, they fitted perfect
Anyhow here's the post of the installation I just dropped on the Challenger Messageboard cos its easier to upload pix on there
http://challenger.mpoli.fi/board/viewto ... 14&t=10025
72 Challenger
65 Barracuda
72 Challenger
65 Barracuda
- Adrian Worman
Where are the discs from in the conversion Dave
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
- Adrian Worman
- Adrian Worman
- Adrian Worman
I finished this at the weekend but I did run into a couple of problems that took a while to sort out.
First was the seal on the rear of the disc hub that protects the larger inner wheel bearing.
My Chally has the early disc spindles on it, which are the same as the drum spindles. I've used a pair of adaptor sleeves from Scarebird that allow the use of the later (73 on) discs on the car without having to change the spindles.
This is well handy if your planning on fitting the larger 11 3/4" Cordoba discs or even in conjunction with a Viper caliper conversion like Steve (AllKiller) did in his Cuda.
For this reason tho the seals that usually fit the large bearing disc, are no good for the early spindles, so I contacted DrDiff in the states and he advised me to use National pt no 4950 seals which offer the same inner seal dia as the ones fitted on the original early discs.
Second was having to grind some material off the splash shields cos the lip on the shield was fouling the disc hub, easy fix tho.
Got it all shoved in and took it round the block to settle the pads and check everything works and it was all good.
Just gotta give the Yellowstuff pads a gentle break in procedure, EBC recommend a minimum 250-300 miles to properly get them bedded in.
Already the brakes have more bite, time will tell if the performance gains are actually that good
72 Challenger
65 Barracuda
72 Challenger
65 Barracuda
