The best place to ask this question
Is this true? I saw this on another site and wondered?
"Now I don't want to give anyone the impression that I think I know everything about cars...'cuz I don't :cheers:
But, being an old(er) car guy that has been studying the subject for close to a 1/2 century it's not everyday I learn something new.
So most of you guys an gals know that some mopar's came with reverse threaded lug nut on the drivers side right? I thought they were the only ones.
But did you know Roll Royce's Had the same design on the lugs well into the '80's? I didn't!
They may still have that design for all I know. :clueless:
:cheers:"
Re: The best palce to ask this question
drewcrane wrote:Is this true? I saw this on another site and wondered?
:cheers:"
do you mean the stud/lug pattern if so it lasted till aroundthe yr 2000 on a bentley till about 2003
I think the question is just about the drivers' side wheel nut threads - did RR's have LH threads too and did they continue that way into the 1980's?
That's the way I read it anyhoo :read2:
Graham Martin
Post by Graham Martin »
I think early ford transits too
RobTwin wrote:I think the question is just about the drivers' side wheel nut threads - did RR's have LH threads too and did they continue that way into the 1980's?
ah that will teach me to not read the thread fully, and yes same applies with the lh thread in the yrs i mentioned, and they all had brass nuts, very expensive
Cannonball wrote: and they all had brass nuts, very expensive
But not what you would want in this weather. :lol:
shovelheadrob
Post by shovelheadrob »
The only difference is that the UK cars will have the l/h thread on the passenger side.
I should be able to find out the answer to this one :thumbright:
Birdman
Post by Birdman »
I have a KIA minibus in the Philippines with LH thread lug nuts on the drivers side. Boy, did I struggle to loosen them when changing a wheel, until, someone suggested they might be LH thread. Great idea really as stops nuts coming loose with wheel rotation, having said that I have changed them to RH on the Satty.
Chris
Adrian Worman
Post by Adrian Worman »
How many years and types of Mopar were they built like this?
Did it just appear on heavy duty drivetrain options?
My Chally has regular studs and so does my little Cuda, my van does too.
Jesus built my hot rod
72 Challenger
65 Barracuda
It was early 70s when they stopped but can't remember exactly when. Think it was done for about 10 years on mopars.
First thing I did was replace all the LHT studs with RHT on my Chally back in 1989. Two had already been snapped off by wrench monkeys.
mad machs
Post by mad machs »
100% true, used to be a tyre fitter, rollers did indeed have LH thread on left hand in a similar fashion to commericals, believe the Bentlys of that era did too.
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
shovelheadrob
My old '58 Desoto had them.
Wow it was late last night and I obviously cant spell "place ".
But this does help with the left nut thing :D
I didnt know that Mopar was not the only one :thumbright:
Cannonball wrote:....ah that will teach me to not read the thread fully....
No worries Dunc, at least you've found the caps lock key :thumbright:
One step at a time, eh ;)
