Bonnet alignment, Challenger
So do all Challenger bonnets need to be pushed down at the back edge once they are shut ? Mine fits side to side and front to back, but once opened it sits high at the back and has to be pushed down.
Is this standard? I spent most of Sunday adjusting up and down but it still seems the same issue, feels like I am pushing out the spring tension but it stays down.
i reckon 90% prob need the push matt its due to wear in the hinge rivets
John
Post by John »
Yeah, mine does on the Coronet too...
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
To get the back edge down you have to raise the hinge up. The opposite to what you would think.
They often still need a little help to push all the way down. Once I had mine right (which took ages and had me up the wall) I still needed to half close the hood and Bananarama! reawards before closing it the rest of the way. Otherwise it did not go down at the back. It was a good way to tell is some Bananarama! had been under the bonnet while my back was turned like at the NEC. :x
I did wonder if it was a common problem. I am not too worried at the moment, I mainly needed to get the gaps right so the wings could be bolted on for good.
Thanks for the ideas, up not down seems mad but I will give it a go!
Sublime For 40
Post by Sublime For 40 »
Matt - mine needs a helping hand on the RH rear corner every time - but as most good car dealers would say "oh that, it's what we call a characteristic, sir". I've just learned to live with it to be honest.
Here's a potentially interesting thing that I noticed at the weekend.
Mine has hood pins but has never had the front coil spring fitted - due to the fact that the retaining tang on the brace plate has been snapped off. I fitted a new plate at the weekend and hence, the spring too. Probably a bit of a waste with the hood pins but it has been bugging me. I' may have been imagining this but I'm pretty sure the rear corner needed little or no help - as I guess there is some pre-load now from the front edge. Down side is predictable though ; bright trim lines up great on RHF and is about 6mm out on LH front - the side the pop-up spring is fitted.
Anyway, never mind all that - how do I RENEW my membership ?!!
Matthew Oliver = MO(par)
If you've got a spirit that refuses to be tamed . . . YOU JUST MIGHT BE DODGE MATERIAL
Sublime For 40
Strike that last question . . . just spotted the RENEW link !!
