after some mopar advise for a non mopar diff, cos your all good on here at busting stuff, me included.
wanting some 3.0 gears for my falcon, 28 spline ford 9"
http://www.summitracing.com/int/search/ ... tio/3-00-1
motive gear = strange eng ? yes therefore 3 options for motive @ 3 different prices ?
and whats stronger 30/10 teeth or 39/13 teeth
what would you buy ?
opinions please
diff gears which brands best ?
life is not a spectator sport
www.andyrobinson.eu
andy robinson
68 572 coronet RT
72 440 chrysler new yorker
69 518 daytona
www.andyrobinson.eu
andy robinson
68 572 coronet RT
69 518 daytona
- mopar_mark
Well in a diff you only drive about 3 teeth at any one time
i'd guess
bigger teeth = stronger but harder to turn over = more parasitic loss each tooth slides further into mesh with its partner = more friction
smaller teeth = smoother and easier to turn but thats 3 smaller bit of metal you are engaging at each instant
think it works the other way for splines
all engaged so the more there are the more surface of spline drive face there is... up to a point dependent on the material, sure hardness and dutctile nature comes into it...soft and you'll rip off the spline
however i am surprised that it isn't a hunting tooth design. i.e mis matched odd and even ring vs Pinion so all teeth mesh at some point with all other teeth rather than the same set.
with the former a fault with 1 tooth gets worn flat by all other teeth on the oposite gear resulting in a minor impact on all of them but distributed over 30 or 39 teeth
with matched teeth a fault would Bananarama! the same tooth on the oposite gear and stamp a similar fault meaning 1 damaged tooth on the pinion always meet 3 damaged teeth on the ring gear.
i'd guess
