Mikes 64 Fury
mike jones
Mikes 64 Fury
Post by mike jones »
With my sons Cal Look Beetle finally finished I’ve started the new Engine for the Fury.
I ran the car a couple of times in 2012 before discovering a badly epoxy patched crack in the block found a new block through the club and ordered a stroker kit from 440 Source. The block is with a local machine shop and should be back in 2-4 weeks (a bit tight for Gary’s Picnic) other work on the job list is
Tidy Engine Bay wiring
Fit MSD and Start /Retard box with a better fix than 2 self-tappers!
Fit grp hood
New torque convertor
Refresh Gearbox
The half shafts were fitted with the adjuster on the wrong side and not knowing if they have been swapped or been wrong since they were fitted I’ll replace them as well,
This is only a start, floor needs patching and I can see daylight between the wheel tubs and the body side but they can wait.
new hood small.jpg (227.6 KiB) Viewed 2011 times
Always liked this car, good luck with the project :thumbright:
Nice to see your back on the car Mike :thumbright:
Is this the x pat bedford car,,,,,,,,,,,
mike jones
thanks Miles and Mark, its been standing for too long :oops:
Yes its Pats old car Duncan
mike jones
pete walton
Post by pete walton »
Mike i have a load chrome trim for these cars ,i got it all from a very nice man up north ..I will not need it all if you have anything missing call me 07970 206827....have some other stuff as well that will not be needed ..nothing exotic but some hard to find trim bits ,,,,
Very nice....and look at that big pile of goodies in the last pic! =P~
GTXJim
Post by GTXJim »
Good luck with the engine build, nice to have met you the other evening :thumbright: :thumbright: :thumbright:
Hell Yeah!! I'm a Redneck
mike jones
Thanks for the loan of the Torque plates Jim, I enjoyed the chat.
Bit disappointed, unpacked my pistons at the machine shop, no sign of any work to balance them, and a discrepancy of 1.7g over the ones tested, the rods show no signs of any rework either, so I will be paying to have it all done again :cry: .Shame realy I've got a lovely piece of paper showing how the calculate the bobweight including a weight for oil
:lol:
balance sheet2014-04-07 18.49.39.jpg (130.79 KiB) Viewed 1888 times
That's a real shame!! Was looking at 440 kit and they have such good reviews on forums
Please chase this up with them and get back to us with update :read2:
Really read build looking forward to this
Loads of pictures and keep the updates coming
Will
mike jones
Will, the parts and the rest of the service was great I just wouldn't bother getting them to balance a race motor
DaveB
Post by DaveB »
Mike,the Pistons should come as a weight matched set,likewise the Rods,the only part to be altered,should be the crank,Sounds a little more like a factory balance(itll do).
I never buy balanced rotating assemblies,because of this :( I get it done over here.
Look forward to the thread Mike.
Very surprising about your parts. Good job you checked them :shock:
Good luck with the build
mike jones
The block is now back from the machine shop, http://www.rolandalsop.com/
along with a balanced rotating assy. I emailed 440 Source about the balance I paid for before shipping, their tolerance is 2.5g, mine is now 0.2g ! I can't recommend Alsops enough and agree with Dave, balance over here, at least you can moan face to face :-) Also uncovered some less then accurate centring on the crank balance, at least no weight was added, to fall out later
small photo block.jpg (26.21 KiB) Viewed 1787 times
crank small.jpg (23.04 KiB) Viewed 1787 times
