hi i have a non mopar master cylinder and booster on my 71 satellite i have been told it could be from a mustang!
I am having problems with it leaking and want to replace it all to either mopar or one that could be recomended by you guys.
It is now running discs up front and drums on the rear.
any help appreciated.
master cylinder/ booster advise
i'd junk the booster and get mopar master cylinder for a disk braked car
get a manual master cylinder pushrod and retaining rubber
your brake peddle should have 2 holes in it use the one that isn't currently in use
its further up so you peddle gives more leverage
simple
less to go wrong
works ok on my car
yours is heavier but your brake discs and drums are bigger
if you have problems with rear wheel lock up
use rear wheel cylinders off a 94-9? Dakota truck
simple
less to go wrong
works ok on my car
