Trigger_Andy
Posts: 7867 Joined: Sun Apr 18, 04 10:27 pm
Post
by Trigger_Andy » Sun Jul 13, 14 7:35 pm
I know this is a Mopar forum but I think there is a few Ford guys here too?
I have a '65 Fastback with a later 302 Engine and I am unsure of the Transmission at this time.
My issue is that all of a sudden I lost reverse completely. :O I parked up no bother but when I came to reverse outta the spot there was nothing. The Mustang came with a B&M Quicksilver Shifter when I bought it and it worked great up till I lost reverse. On the 10 mile drive home Im sure the transmission sounded and felt different but I was so worried Id not make it that it may have been my imagination. The oil level is good and the fluid smells as it should.
Anyone jave any suggestions? Im looking to sell it as Im moving back to Scotland in a couple of months and this is the last thing I need.
Bryan
Posts: 972 Joined: Sun Apr 18, 04 11:27 pm
Post
by Bryan » Sun Jul 13, 14 8:00 pm
not sure about your problem but the transmission will probably be a C4
Trigger_Andy
Post
by Trigger_Andy » Sun Jul 13, 14 8:07 pm
Cheers!
DaveBishop
Posts: 1667 Joined: Sun Apr 18, 04 11:22 pm
Post
by DaveBishop » Sun Jul 13, 14 8:08 pm
Does it go into D1
2 x 1969 Dodge Darts
Trigger_Andy
Post
by Trigger_Andy » Sun Jul 13, 14 8:16 pm
I had to travel off-shore Dave so I cant look till Wednesday.
DaveBishop
Post
by DaveBishop » Sun Jul 13, 14 8:31 pm
Hi Andy if it goes into drive but not D1 or reverse its the rear band usually but it could be the shifter playing up
Trigger_Andy
Post
by Trigger_Andy » Sun Jul 13, 14 8:43 pm
Cheers Dave, first thing Ill look at when I get home.
If thats the case is this a complex or fairly simple fix for a Mechanic who knows his way around American cars to an extent?
Trigger_Andy
Post
by Trigger_Andy » Wed Jul 16, 14 4:32 pm
OK, just got home and I can confirm that the Muzzie drops into D1 and D2 as well. Reverse is still not there.
DaveBishop
Post
by DaveBishop » Wed Jul 16, 14 4:36 pm
I would mess about with the shifter
Trigger_Andy
Post
by Trigger_Andy » Wed Jul 16, 14 5:13 pm
OK, cheers.
This could be disastrous.
DaveBishop
Post
by DaveBishop » Wed Jul 16, 14 5:55 pm
Just put the rear end on axle stands chock the front wheels hand brake on disconnect the shifter start the motor and let it tickover and try and lay under and click the shifter by hand if you have a pit or ramp much better
Gareth
Posts: 1547 Joined: Tue Dec 07, 04 9:23 pm
Post
by Gareth » Wed Jul 16, 14 11:14 pm
Trigger_Andy wrote: OK, cheers.
At least your eyebrows should be safe this time ! Try not to run yourself over.
Posts: 9568 Joined: Thu Feb 24, 05 10:31 am
Post
by Dave999 » Thu Jul 17, 14 4:10 pm
yeah and the exhaust.....it gets hot....eventually.. so if it was a squeeze to get under beware poistion yourself where passage under either pipe is not necessary
Trigger_Andy
Post
by Trigger_Andy » Fri Jul 18, 14 5:00 am
Gareth wrote: Trigger_Andy wrote: OK, cheers.
My eyebrows have never been the same since.
Trigger_Andy
Post
by Trigger_Andy » Fri Jul 18, 14 5:01 am
As it turns out there is a Ford Transmission specialist not 2 km from my house and the Muzzie is booked in there this morning. Result!
