B Body Leaf springs - factory specifications?
Sean
Post by Sean »
Hoping someone can help....
I'm re-tempering my leaf springs on my '69 Charger...
I have dropped them off with GME springs in Cov, but they need to know the original spec for the "Free Camber" - (That's "C" in my little pic)
I can't find any info anywhere about the Arch (A) or the Pack Thickness (B)... so I'm really hoping someone can advise??
Just looking for a stock look. My springs were shot and sat almost flat with just the weight of the car on them!
Any Help much appreciated !!
leaf springs.jpg (57.37 KiB) Viewed 937 times
Sean
Post by Sean »
:tumbleweed: :tumbleweed: :tumbleweed:
Wish I could help Sean. Just checked my manuals and gives lots of information , but nothing on the dimensions you are after.
Sorry. :(
Sean
Post by Sean »
Thanks Gary - I found that chart this evening too! Great minds....and all that.
I'll pass that on to the guys doing the re-tempering - cheers
springs should also have zinc interleaves and plastic sliders
plastic sliders used to be about 15-20 quid for 4 via WASP
i made my own zinc bits
0.9mm sheet off ebay
cut into strips as wide as the springs
drill hole in middle of the end 1 plastic slider length from the end
put between leaves facing forwards to allow springs to slide as they bind up under acceleration
trim off just short of the plastic
don't need any oil grease or slimy tape on ya springs then
paint em black and off ya go
totally self lubricated
and as per original
unless you particularly want to spend $200 per spring for a repro set of zinc bits....
Mopar do em also but their zincs are just galvanised steel....and they don't work well.
Sean
Post by Sean »
Thanks for top tip Dave...
I'll certainly look into that :read2:
