Pick your brains !!
Pick your brains !!
Just want to run through a few things with you clever lot if I may.
I may have a diff coming cheap with 3.90 gearing. Not exactly what I'm after but beggars can't be choosers. Should give me the opportunity to rebuild diff, then swap , and if I'm not happy I can swap back.
I have roughly calculated that at the moment with a tyre diameter of 26.4" and my current 2.76 gearing I should be at 2124 rpm at 60mph ?
By changing just the gearing I should be at 3024 rpm at 60 mph. Sound about right ?
Still on a stock convertor , but am I correct in thinking for race purposes one would aim to get a convertor near to the rpm at 60 mph for a good " launch" set up ?
Also. Engine is pretty much stock apart from carb, intake and exhaust etc. stock convertor.
How will it behave by adding the 3.90 gearing ??
I understand it will be a good test of bottom end strength !!!
Cheers.
I think you will be pulling 3200 rpm at 60 mph with 3.91:1 gears, allowing for transmission losses....
Convertor choice is determined by the gears, cam and the amount of torque the motor makes - it will stall later in a small block than in a big block........
Cheers Pete. Still much to learn :read2:
Worth a try then ?
Of course its worth a try - it''s not my car ;)
It will liven it up a bit, which is nice...
Thank you Pete. Any advice appreciated. :thumbright:
John
Post by John »
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Cheers John. Looks like a good site for info. :thumbright:
It'll be screaming its nuts off! I had those gears in my Dart for a bit. Maybe get taller tyres to relax the gearing a bit. I settled on 3.55s but like you my 3.91 set came very cheap.
MilesnMiles wrote:It'll be screaming its nuts off! I had those gears in my Dart for a bit. Maybe get taller tyres to relax the gearing a bit. I settled on 3.55s but like you my 3.91 set came very cheap.
Thanks Miles. I've been looking at tyre size and how it effects the gearing.
3.55's are what I want , but I will try the 3.90's. Worth a laugh !!
:lol:
I run tall tyres on the Bee - with 4.10:1 gears it works out at 1000 rpm per 20 mph... you can live with that...........
Pete wrote:I run tall tyres on the Bee - with 4.10:1 gears it works out at 1000 rpm per 20 mph... you can live with that...........
Mmmm. Got a mate with a tyre shop at the top of my road. I'm sure experimenting will be fun ! ;)
This is the calculator I made myself. It's the only one I would use.
http://challenger.mpoli.fi/web/AUTOMATICchart.xls
Thanks Dave. :thumbright:
Les Szabo
Re: Pick your brains !!
Post by Les Szabo »
Mossy68 wrote:Just want to run through a few things with you clever lot if I may.
Cheers.
Generally yes, but not in your case. If your powerplant made good hp from say 2800>6000, you would put a 3000>3500 verter in it. Your engine makes power from around 1500>4500, so leave the stock verter and with 3.91's/27" tyres you'll go through the top end in 3rd at around 4400 which is bang on max power and ideal to give you your best shot at a good ET.
For street, it'll be harder on your box, your wallet and your motor, but the feel factor may just be worth it to you?
Les
