Can anyone answer me the old question as to whether Hydraulic handbrakes are road legal? I was told a few weeks ago that they won't accept them on MOTs? I am thinking of converting the rear of the rambler to discs using small calipers and a Hydraulic HB (unless i can get some with built in HBs).
Ibelieve the MOT requires a "mechanical" hand brake, but I know off at least one Mopar with a hydraulic. Think it depends on your friendly MOT man.....If you know what I mean
<center> The name is Kev, nowadays known as Kevvy or Pommie C***!</center>
when i do a rear disc conversion i usualy use sierra or granada rear calipers, thay have a built in handbrake mechanism and all the cable mounts are on the caliper so its easy to connect the cables .
Yes i wondered about that cos i used to race a cossie.I suppose its just the same set up when fitting to escort axles.Make a bracket to mount it on and get some granada discs? What discs would you use?
I've looking into rear disc conversions and there are several, although I must say I didn't get as far as determining whether the HB was cable, it then got put on the "later" pile
