Power steering box, anyone had one apart?
Found the leak on my Fury steering box (box looks the same as most mopar boxes) To my surprise its NOT coming from the shaft seals but from the edge of that round cover thingy facing the steering column.
(held in by an enormous castellated round threaded ring by the looks of it)
Whats in there, is there a special tool required? is there a gasket? o-ring? Can it be take off in situ?
help!
help!
Im no position to say this is right, and hopefully some who knows will join in thread, but I thought you could tighten that nut down a shade and reduce loss. Thats what i did with my first Chally and it worked for a little while (whole box gave up the ghost later though!), not sure if that alters adjustment aswel.
okay i pulled the column out and got the pesky steering box out . What a horrid oily heavy job that is. Its like a Rubik puzzle getting that box out once you've undone it! (and not crushing your fingers or dropping it on your head) Still, i bet its harder on a Charger or something. not even sure Charger ones come out without removing some other parts first.
Anyways, ya know that subframe I imported for my ragtop, low and behold theres a steering box on it. I'll be putting that in tomorrow, and crossing everything i've got that it works.. and doesn't leak!
