Mogwai's Charger
Mogwai's Charger
1970 Dodge Charger r/t.
Been off the road for years, needed basically everything!!
Engine and gearbox in and running, just about!
It does have a matching numbers engine and box with intact fender tag.
This engine and the car I got from Duncan Watts.
I really don't know now, I have gone off in alsorts of directions!
Fuel cell fitted now.
I have done most of the work myself, my dads advised me on many things, but really it was a case of just get stuck in.
I hated doing the body work and to be honest it wont look that good this time round.
I just want it out on the road asap, as my luck goes there will be plenty of other problems to follow!
She is not straight enough at the minute to be a darkish colour!
Originally FE5 bright red with black vinyl roof.
It will be a shade of red for this time round, but would love it to go back to original, with Rallye wheels but the aftermarket kind that are a bit wider.
It should have a twin stripe (longitudinal) down the side, not my cup of tea.
I prefer the stripe over the rear and the 440 on the hood.
It has Jaz seats now on the inside, with a 5 point harness.
B&M Ratchet shifter with reverse pattern valve body.
Mopar 5" Tacho with shift light, and Mopar Volt,Pressure,Temp Gauges.
Jeez will these loans ever end!!!??
i was very lucky with my dart i bought it blind and it only needs a handfull of things i can only guess at this point what its like although two freinds chargeruk [martin] and phill440 are having there chargers restored so i kinda know whats its likeMogwai wrote:.
