68 Charger front wheels query
Rebel
Post by Rebel »
I've changed from power to manual steering and have 7x15 front wheels, now that the steering is a lot heavier at parking speeds ( obviously expected this ), I know a narrower front wheel would help but, my current ones fill the arch nicely and I'm wondering how a narrower one would look. Are spacers with a narrower wheel an option or a no no?
Don't really want to go to the extreme of a 3.5 so was thinking of maybe a 5 or 5.5, I know I could fill the arches by using the inset and offset but concerned about putting undue pressure on the bearings.
What's everyone else done to get the wheel to look right in the arch?
TIA
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
pump your tyres up and get the front end castor checked.
what ratio steering box did you go for
24:1 or 20:1 or 16:1
16:1 would be a struggle in all but a light A body but the chances of finding one in 16:1 is minimal.
how wide are you wheels
20:1 ratio with 225 65 R14 on the front of my car was ok 195 is better
the 225 65 was about 8 inches across the treads on a 7 inch rim
the 195 is about 6.5 i think
this is what they look like
Hot Rod Drags 2010.JPG (63.91 KiB) Viewed 638 times
Rebel
Post by Rebel »
I'm not sure what the ratio of the steering box is, it was second hand, not new when I bought it from another member.
I have 7x15 wheels with 235/60/15 cooper cobra tyres on at the moment
'68 Dodge Charger
‘75 Ford Ranchero
I have tall and skinny radials on my Bee - 205 x 70 x 15. #no gaps.......
Makes the rears look even wider
Rebel
Post by Rebel »
Do they look as though they fill the front arches Pete?
'68 Dodge Charger
‘75 Ford Ranchero
No gaps at the top but it will never fill arch like a 235.
My Fenders are more slab-sided than a Charger.
Only other option is wheels with more Back-spacing.............
Rebel
Post by Rebel »
Hmm, research on back spacing and wheel options required me thinks,
Thanks Pete
'68 Dodge Charger
‘75 Ford Ranchero
