Duff Diff?
Duff Diff?
I'm still trying to track down the cause of a major vibration at over 60mph.
I've norrowed it down to the rear end so pulled one of the half shafts & about 5 litres of horrible, very very thick burnt smelling oil poured out.
I filled the diff up with limited slip oil last year as it was almost dry.
This normal?
This normal?
Shaun 'Moparless' Senior
MMA Club Chairman
MMA Club Chairman
Perfectly normal, they came out the factory like that!!!
It May / many not be the cause of your vibration, but I think you have something else to spend your hard-earned pocket money on......shafts out, prop off(again, probably...) Pig out and examine, then weep slightly and reach for a Guinness............
The rear diff should only have about 2 litres of oil not 5.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
check the uni joint at the diff end is seated properly
undo it
be careful not to let the caps fall off...the rollerers will fall out
check that both caps still have their snap ring on and it is seated in the groove
turn both caps round so that the back of the snap ring is facing into the diff yoke
tap it gently back in making sure the cap snap rings seat inside the yoke saddles and do up the straps to very-short-spanner- in -my- left hand tight. inch lbs not foot Lbs
if you wanted to you could spin the wheels while the tail shaft is down and just check the center of the diff yoke nut stays in the center as the pinion turns
a diff that has had the rear end of the tail shaft grounded can suffer from a bent pinion.
diff oil and gearbox oil always stinks....
try getting it all over your head...the smell stays with you for about a week regardless of how much swafega and head n shoulders gets used.
dave
undo it
dave
Well I've pulled the other half shaft & diff but can't see any issues. How likely is it that it's too much bad oil that's causing the over 60 mph bad vibration (more like a pulsing)?
I'm thinking of dropping the gears from 3.91 to 3.23 while I've got it out as she's not going to be used on the strip. That is if I can get the dam uni joint bolt undone!!!
MMA Club Chairman
MMA Club Chairman
I think the passenger side one (left of the picture) MIGHT have a very slight bend at the hub.
Yes Dave I've marked them so I know which side the came out of but may need a new passenger side one - need to have a good look at it over the weekend.
I'll also get the 3.23 gears in to hopefully improve the driving comfort over the 3.91's.
Measured the oil out of the diff & there was over 5 litres, how is that possible if it should only hold 3 pints?? Is there a seal to pervent the oil going into the shafts?
MMA Club Chairman
MMA Club Chairman
