helicoil on an iron head
Dart Vader
Post by Dart Vader »
Can this be done?
Got a stripped thread on each end of the heads, last bolt so water corroded.
Any tips?
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
yes no problem they are 3/8 unc,,,,,,
yep love a heli coil buy as a little set with the correct tap and drill bit and tool
Dart Vader
cheers, was a bit worried the iron would be too tough.
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Cast iron isn't that nice to drill, it tends to snatch a bit. Make sure the head is firmly held down, drill on a slow speed with a good firm grip on the drill and take it easy, you should be fine. Don't risk snapping the bit off in the head or you'll be in a world of Bananarama!.....
As Blues said, drill nice n slow, you shouldnt need to lubricate. But make sure you do when tapping.
Keep backing the tap out, as they tend to clog quickly with cast iron.
bratfink
Post by bratfink »
If you can setup to use a pillar drill or even better a mill it'll be easier to get a nice cut (if the head is off of course - be a bit tricky if the head is still on the engine)
if this is the same size as a 727 sump pan i have a kit you can borrow
