Indexing plugs
Turnip
Indexing plugs
Post by Turnip »
Hi all,
What are your thoughts on indexing spark plugs. Some say it should be with the strap facing the inlet and others facing away.
After trying it both ways my thoughts are it makes sod all difference in a Mopar wedge head.
My thoughts too, the plug is in such a lousy position anyway I wouldn't have thought indexing would make a blind bit of difference.
face the gap towards the exhaust valve...
thats the hotest area
so it will go off better
and that comment is based on absolutely nothing to do with cars or experience or anythig really other than GCSE chemistry
hot stuff does faster chemical reactions than cold stuff so will cause a more dramatic expansion!!!!!
think its probably just an idea someone had because he had a lot of very narrow thin washers to sell.
The spark will go off the electrode at a different place every time as the sharpest point (the place where a spark tends to go from) it went from last time was erroded away by the spark produced from it.
side gapped plugs is another thing that Might MIGHT work, but again subjected to sharpest closest point between centre and strap
and then there are the plugs with the kinda ball bearing centre electrodes...
shovelheadrob
Post by shovelheadrob »
Only ever had to bother with indexing on one engine, when we used to race in Super Modified the motor we used was a bit tight on clearance & if the plugs weren't indexed the pistons would close them up a bit! Other than that I think it's not necessary.
shovelheadrob wrote:Only ever had to bother with indexing on one engine, when we used to race in Super Modified the motor we used was a bit tight on clearance & if the plugs weren't indexed the pistons would close them up a bit! Other than that I think it's not necessary.
Now that's working to tolerances ! :shock:
Turnip
Post by Turnip »
We had a few visits from Michael ( the owner of the Samantha Pro Stock team) and his crew trying to help us with some problems we were having.
They told us to cut the strap back to a point and then face the open side to the inlet :dontknow:
An old race trick used to be to grind the centre electrode to a point. The plug will not last long like that of course.
Sparks jump easier, faster (and at a lower voltage) from a sharp point.
But I don't see that adding power or fixing any issues with the way the engine runs. It might be a crutch for an ignition system not working correctly though.
Turnip
Post by Turnip »
We were have a misfire issue at the time but cured that by putting the MSD in the bin
Guy
Post by Guy »
Turnip wrote:We were have a misfire issue at the time but cured that by putting the MSD on the bin
I didn't know you called your car that :shock: but I have heard you call it by some other names ;)
Les Szabo
Post by Les Szabo »
Turnip wrote:We were have a misfire issue at the time but cured that by putting the MSD in the bin
Suprised you don't use the FBO ignition, certain people say they outperform MSD...
Les
Les Szabo
Post by Les Szabo »
internet :evil:
GTXJim
Post by GTXJim »
years ago I read that indexing the plugs gave you an extra HP per plug, 8 free HP, they said you aim the electrode towards the exhaust valve, did it on the GTX couldn't tell the difference, don't bother now, I know Dave Wilson indexes his plugs on his Nitro TMD, they are a twin plug BAE Hemi and he has the electrodes facing each other.
Hell Yeah!! I'm a Redneck
GTXJim wrote:years ago I read that indexing the plugs gave you an extra HP per plug, 8 free HP, .
Putting a magnet on your fuel line and fitting an electric fan above the carb both give you more HP than that. :lol:
