Sway Bars
lough3969
Sway Bars
Post by lough3969 »
Any one have any recommendations for sway bar kits for a SB 360 68 dart? Lots about but I'm sure some are better than others.. [/i]
Front or rear?
If front, do your LCA's have the brackets on them?
I may have a set of LCAs with the brackets but will probably need new bushes (as usual)................
lough3969
Post by lough3969 »
Ah I'm not sure... Think they are stock, so probably not? Actually thinking this through it might be a whole heap of trouble to do... Was a slant six and was converted with a Schumacker kit.... Maybe it's a bigger job than i first thought.. I will have to do some further reading up methinks...
:read2:
Thanks for the offer though. :thumbright:
If it is going to see a fair bit of Strip action I would not bother, you want a loose Front end !! :shock: :shock: :shock: :shock:
lough3969
Post by lough3969 »
Well that's saved me a lot of trouble :D Bad sway bar! :P
