1, 69 Charger with 440 fitted, rear oil seal leaking, can it be changed with engine in easily? Only seems to drip on tickover when warm/hot, has been fine for 6 years.
2, I have a ford (I know, not mopar) 460 motor, silent on tickover but I get one lifter that taps when accelerating, could it be collapsing when under load?? Fine when cruising at higher rpm's, just taps when the old loud pedal is pressed.
Any advice appreciated
