Basic Fuel question
sprintgtvgus
Basic Fuel question
Post by sprintgtvgus »
On my 440, should the fuel filter look full? It is a new one but appears to be only half full.
Just speculation as I have had the car cut-out a few times, sometimes on hills.
I do have a new fuel pump if needed (manual)
This Thursday I'm going for rolling road set-up and to measure afr etc, not sure that the carb or the timing is correct really.
Yes should only be half full
if i was you i would forget the rolling road and spend your money at Antons garage
He is a member on here and lives and breathers mopar
http://www.apdautomotive.co.uk/
If you want it to run right he is your man
:thumbright: :thumbright: :thumbright: :thumbright:
Buy an AF set up and then you can se how it performs in real life situations.
Mine has been a great asset. Just tuning the carb for idle was straightforward as was swapping out jets etc and checking the different AF readings.
£150 and you have it there all the time as opposed to a one off rolling road tune. You might want to change things down the line ie fitting a 3/4" spacer leaned my car out nicely and the AF gauge showed that.
sprintgtvgus
Thanks, good to know.
I am going to stick with the dyno now as they are going to set the timing and fuelling (I have a box of jets and springs) and they seemed to do a good job with my alfa.
Measuring the AFR under load and seeing what get's best power isn't a bad thing.
I don't have an exhaust lambda port yet, and frustratingly I sold an innovate wideband a year or so ago as I thought I wouldn't need it....!
Mick70RR
Post by Mick70RR »
If you can see the fuel in the fuel filter change it for one that's not made of glass or plastic.
CRAIG
Post by CRAIG »
How come glass or plastic filters are no good?
1969 Dodge Charger
1972 Chrysler Hardtop
MrNorm
Post by MrNorm »
CRAIG wrote:How come glass or plastic filters are no good?
Significant fire risk, especially in crash. But great for seeing if you have fuel. Wish there was a safe way to achieve that, I looked a while back but didn't find anything practical (not much point right now :oops: )
Bilko
Post by Bilko »
If they are anything like the ones made for Harleys they always leak.
Yes either type can crack and leak, not good. I've had a fuel fire and it ain't funny.
MrNorm wrote:......(not much point right now :oops: )
sounds ominous, Gav :shock:
