Timing light
Timing light
What timing light would you recommend for a complete novice?
Regards
Bryan
Regards
Bryan
The BEST sort is known as a "Count back" whereby you always strobe at TDC and the timing light displays the amount of advance or retard in degrees - this works with any damper that only has basic marks and not degree marks all around it like most SFI approved ones. Very easy to use.
I have a "Snap On" that I swear by, but they are a lot of money.....
Hi,
Have a look in this thread as there are a few brands mentioned:
http://www.moparuk.com/forums/viewtopic.php?t=49894
I went with the Dave/Anton recommendation of the Equus Innova 5568. Haven't had a chance to use it in anger yet but it has Tachometer functionality built in as well.
Manual is here if you wanted to have a look:
http://innova.com/Content/Support/Manua ... 5568_E.pdf
adrian.
adrian.
- Adrian Worman
Snap on ones are super - can set them to do all sorts of things. But they are pricey.
If you are after basic stuff, I just went with one of these. The key thing is being able to set the advance so all you have to worry about is the big-ol-mark on the bottom pulley-harmonic thingy. Static ones without this are a pain.
The thing that is also useful (which this doesnt have and the snap on does) is a tachometer. I got round this by buying a £5 jobby from ebay and putting a couple of croc clips on it...
Pay yer money, takes yer choice. But if you are just doing the occasional sanity check this should do it at a budget.
- timing.jpg (33.8 KiB) Viewed 1458 times
I bought one of those a while back when my old faithful snap on finally gave up the ghost. It worked fine until the second time I went to use it, was giving all sorts of strange readings and then it failed altogether....
Just bought 2 used Snap on's, hopefully at least one of them will work, they are by far the best.
- Powermyster
I have one of these
http://www.ebay.co.uk/itm/Gunson-G4123- ... 3a9cf2743a
Not cheap but does everything you want from a timing light plus leads are replaceable. You get what you pay for.
*MMA-609*
"Built to be driven!"
Why me???
*MMA-609*
Why me???
