Power steering leak. Any culprits?
I have quite a leak but the Hoses seem good, there is steering fluid around the actual steering box, but i cant see where it's coming from.
Any usual suspects?
Any usual suspects?
Check the seal behind the pulley on the shaft, the unions where the HP hose and return hose connect, crack or split in the reservoir case. Has it been over filled?
And finally, when driving do you constantly have to use full lock, this causes a build up of pressure in the system ( you can hear it from inside the car ), watch the pipes attached to the pump when the steering is on full lock and you'll see them twitch. This can cause an over flow depending on the amount of fluid in the reservoir.
Are both hoses correctly seated in the steering box?
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
‘75 Ford Ranchero
The seals in the connector on top of the box that takes both the high and the low pressure hoses Miles?
There are o rings under the flat part that can leak making it very hard to see where it`s coming from.
Anton has such seals, easy job but if you do it be carefull to put it back on correctly adjusted as it slides up and down or your steering will be very notchy.
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Now passed customs.
Now on route.
Now in posession.
Can be easily done Miles, depends on knowledge of how to check the level correctly, most reservoir dipsticks are marked for checking the level hot and cold, but not all of them are.MilesnMiles wrote: Don't recall ever overfilling the reservoir.
'68 Dodge Charger
‘75 Ford Ranchero
‘75 Ford Ranchero
Hey Rebel, that would be correct...if I had a dipstick and lid! Mine disappeared down the road some while although I never overfill as I know from experience where the level should be.
I have a rubber bung in mine which doesn't leak.
It's just occurred to me though, does the original cap have an air breather on it? I have I inadvertently presssuried the system with my home made cap?
Just a thought.
Just a thought.
I'm not 100% certain whether they have a breather or not Miles, I can't check either as I no longer have power steering in the Charger, hopefully someone with more knowledge will know.MilesnMiles wrote:It's just occurred to me though, does the original cap have an air breather on it? I have I inadvertently presssuried the system with my home made cap?
Just a thought.
Dunc might have a PS cap kicking about somewhere,
If that's what's causing the leak, I would think that the outside of the filler neck would be soaked in fluid as well though. Might be an idea to clean the outside of it ( if it's grubby ), go for a drive and check it when you get back
'68 Dodge Charger
‘75 Ford Ranchero
‘75 Ford Ranchero
Refer to my first post MilesMilesnMiles wrote:The leak is definitely from the main body. Reservoir is fine and hose connections look good. It appears to be leaking from behind two main bolts that face upwards from the main body.
Now passed customs.
Now on route.
Now in posession.
Now passed customs.
Now on route.
Now in posession.
