Hi all,
Does anyone know the maximum valve lift and installed spring height on Indy 440 EZ-1 heads?
Indy are being their usual helpful customer service!!
Thanks
Indy heads
Re: Indy heads
Turnip wrote:Hi all,
Indy are giving their usual helpful customer service!!
Thanks
you asked twice so I asked the internet
http://www.hughesengines.com/TechArticl ... ntakes.php
EZ head Same as stock according to Mr hughes
EZ-1
The 440 EZ-1 is the same cast head as the 440 EZ with the intake openings CNC machined to the Max Wedge size and CNC bowls. This allows all Indy manifolds to be used or all after market Max Wedge X-rams. Both EX and EZ-1 use standard Chrysler rocker shaft oiling. Standard low exhaust port.
so in my book exactly the same as a stock 440 head
dunno what that is though
dave
EZ-1
dave
no I assumed that for a standard/stock head it would be plastered left right and centre all over forZbodies only and allpar
must be in the books somewhere
you going for mental cam? offset retainers?? more spring,less bind,same valves, Bananarama! reatiners etc oh just a little notch will be fine honest etc etc
I know nout about V8s let alone those that use fancy aftermarket heads
hence I approached cautiously
